Hi
I’ve a question about dashlet with icingaweb
I’ve an icinga infra with 2 masters. All is working fine.
But I’ve a problem with dashlets.
My users can create dashlet, but they are not replicated on icingaweb config.
On /etc/icingaweb2/dashboards/ I can see my users directories with their dashboard.ini but they are either on master01 or aither on master02
Do you have an idea where I can fix it?
Alex
theFeu
(Feu Mourek (they / them))
May 14, 2020, 12:32pm
2
I moved this to the Icinga Web category, as it seems more fitting
elippmann
(Eric Lippmann)
June 5, 2020, 9:51am
3
Icinga Web’s configuration is completely separate to the Icinga 2 configuration itself.
If you run Icinga Web high available or load balanced, you have to manage the synchronisation of the configuration on your own, e.g. via rsync or a network storage.
But there are plans to store Web’s configuration into a database, e.g. https://github.com/Icinga/icingaweb2/issues/3809 .
Does this help?
All the best,
Eric
theFeu
June 10, 2020, 1:24pm
4
Hello @enigma619 !
Did you manag to resolve your issue in the meantime?
I would love to read an update from you!
Have a nice day!
Feu
