log1c
January 22, 2024, 8:52am
1
Hi @Icinga Team,
the icinga package repository for IcingaForWindows is still missing the Icinga2 Agent installation version v2.14.1
I have mentioned this on github as well a week ago, but it is still missing.
opened 09:54AM - 19 Dec 23 UTC
# Release Workflow
- [x] Update `ICINGA2_VERSION`
- [x] Update bundled Windo… ws dependencies
- [x] Harden global TLS defaults (consult https://ssl-config.mozilla.org)
- [x] Update `CHANGELOG.md`
- [x] Create and push a signed tag for the version
- [x] Build and release DEB and RPM packages
- [x] Build and release Windows packages
- [x] Create release on GitHub
- [ ] Update public docs
- [x] Announce release
## Update Bundled Windows Dependencies
### Update packages.icinga.com
Add the latest Boost and OpenSSL versions to
https://packages.icinga.com/windows/dependencies/, e.g.:
* https://master.dl.sourceforge.net/project/boost/boost-binaries/1.82.0/boost_1_82_0-msvc-14.2-64.exe
* https://master.dl.sourceforge.net/project/boost/boost-binaries/1.82.0/boost_1_82_0-msvc-14.2-32.exe
* https://slproweb.com/download/Win64OpenSSL-3_0_9.exe
* https://slproweb.com/download/Win32OpenSSL-3_0_9.exe
### Update Build Server, CI/CD and Documentation
* [doc/21-development.md](doc/21-development.md)
* [doc/win-dev.ps1](doc/win-dev.ps1) (also affects CI/CD)
* [tools/win32/configure.ps1](tools/win32/configure.ps1)
* [tools/win32/configure-dev.ps1](tools/win32/configure-dev.ps1)
### Re-provision Build Server
Even if there aren't any new releases of dependencies with versions
hardcoded in the repos and files listed above (Boost, OpenSSL).
There may be new build versions of other dependencies (VS, MSVC).
Our GitHub actions (tests) use the latest ones automatically,
but the GitLab runner (release packages) doesn't.
As we use the option to create a local repo for IfW and like to install the agent on the same version as the master/satellites, the blocks our progress somewhat.
Would be awesome if the installer could be added asap
cheers
2.13.9 and 2.14.2 are missing too
log1c
February 9, 2024, 7:32am
3
the most recent versions are still missing.
@Icinga
is there no automation behind uploading the packages to this part of the repository?
Al2Klimov
(Grandmaster)
March 12, 2024, 12:07pm
4
Now I’ve built the automation.
