Icingadb-web limited host search results
there is no specific tag for icingadb-web but I have a question about this.
Are there users who only use icingadb-web with the monitoring module completely disabled !?.
I would like to run full icingadb/icingadb-web but when I do a global search to find a host , I don’t get the same result when I do this with the monitoring module.
Before I have results based on the object name, address, and the display_name fields.
Like:
object Host “redhat_host_192.168.000.001”
address = “192.168.0.1”
display_name = “myhost.be”
When i search redhat_host then it finds all hosts with redhat_host in the object name.
When i search 192.168.0. then it finds all hosts starting with 192.168.0. in the address field.
When I search myhost it finds the host based on the display_name
I have the impression that he is now looking only in the object name.
When I check the search filter for hosts , it only searches for the hostname in the ‘Host Name (CI)’.
I do think that the intention is that the icingadb-web wants to be have the same search results as in the current monitoring tool/module.
I asked the question via github icingadb-web.
(find nothing of hosts when do global searching based on display name or address · Issue #690 · Icinga/icingadb-web · GitHub)
Just wanted to know if I’m the only one with this problem or if there are other users out there who have the same experience.
System information:
Icinga2 : r2.13.6-1
Icinga Web 2 Version : 2.11.4-1.el7
IcingaDB Web : 1.0.2-1.el7
icingadb : 1.1.0-1.el7
icingadb-redis : 7.0.5-1.el7.icinga
Platform: Red Hat Enterprise Linux Server 7.9 (Maipo)
PHP Version 7.3.33
icinga/icinga-php-thirdparty 0.11.0
icinga/icinga-php-library 0.10.1
Regards,
Geert
