Is anyone else having problems using the latest icingadb-web version (1.1.0), and Nagvis? Spefically, I am seeing an exception thrown due to Nagvis attempting to implicitly convert a DateTime object to an integer (which, as far as I can tell, was never actually supposed to work anyhow). The greater issue seems to be that, somehow, the icingadb web module is causing a PHP Notice, that is usually invisible to the user, to be thrown as an ErrorException, which breaks Nagvis map viewing. I’ve had a look but I could not yet track down where the switch actually happens. All I can see is that after including the Icinga EmbeddedWeb class and issuing the “start”, the PHP Notice will then be thrown as an error.
Simply downgrading to icingadb-web 1.0.1 causes the issue to go away.
- Icinga DB Web version (System - About): 1.1.0
- Icinga Web 2 version (System - About): 2.14
- Web browser: Firefox
- Icinga 2 version (
icinga2 --version): 2.14.0 - Icinga DB version (
icingadb --version): 1.1.1 - PHP version used (
php --version): 8.0
