My setup has a primary and secondary in the Master zone, and then multiple other zones each with two satellites. Each master has its own independent Redis instance, icingadb instance, and they share a backend database (mysql).
Both masters are running checks, and the system seems fine. I got an alert about memory usage on my secondary master, and started looking into it - yesterday Redis RSS was at 1.4GB, today at 1.8GB.
When I check various Redis keys/streams, the secondary’s are much larger than the primary:
The memory usage is also vastly different:
| Key | Bytes (Secondary Master) | Bytes (Primary Master) | Column 4 |
| icinga:checkcommand | 152777 | 141033 | |
| icinga:checkcommand:argument | 1133889 | 1178600 | |
| icinga:checkcommand:customvar | 376880 | 376880 | |
| icinga:checkcommand:envvar | 1923 | 1923 | |
| icinga:checksum:checkcommand | 41032 | 41032 | |
| icinga:checksum:checkcommand:argument | 507960 | 507960 | |
| icinga:checksum:checkcommand:envvar | 720 | 720 | |
| icinga:checksum:comment | 296 | 296 | |
| icinga:checksum:downtime | 18360 | 22848 | |
| icinga:checksum:endpoint | 204192 | 204192 | |
| icinga:checksum:host | 221728 | 221728 | |
| icinga:checksum:host:state | 221736 | 221736 | |
| icinga:checksum:hostgroup | 3144 | 3144 | |
| icinga:checksum:notification | 7874264 | 7874264 | |
| icinga:checksum:notificationcommand | 720 | 720 | |
| icinga:checksum:notificationcommand:envvar | 7256 | 7256 | |
| icinga:checksum:service | 8079760 | 8079760 | |
| icinga:checksum:service:state | 8079760 | 8079760 | |
| icinga:checksum:servicegroup | 1864 | 1864 | |
| icinga:checksum:timeperiod | 968 | 968 | |
| icinga:checksum:user | 3136 | 3136 | |
| icinga:checksum:usergroup | 712 | 712 | |
| icinga:checksum:zone | 203368 | 203368 | |
| icinga:comment | 1600 | 1600 | |
| icinga:customvar | 1983880 | 1983880 | |
| icinga:downtime | 114313 | 149304 | |
| icinga:dump | 9824 | 4736 | |
| icinga:endpoint | 557464 | 557464 | |
| icinga:history:stream:acknowledgement | 412 | 412 | |
| icinga:history:stream:downtime | 396 | 396 | |
| icinga:history:stream:flapping | 396 | 396 | |
| icinga:history:stream:notification | 404 | 396 | |
| icinga:history:stream:state | 396 | 404 | |
| icinga:host | 1477208 | 396 | |
| icinga:host:customvar | 1917616 | 1477208 | |
| icinga:host:state | 1670368 | 1917616 | |
| icinga:hostgroup | 12136 | 1747628 | |
| icinga:hostgroup:member | 1054312 | 12136 | |
| icinga:nextupdate:host | 191028 | 1054312 | |
| icinga:nextupdate:service | 6939187 | 198272 | |
| icinga:notes:url | 1008 | 6592480 | |
| icinga:notification | 45920528 | 1008 | |
| icinga:notification:customvar | 31248 | 45920528 | |
| icinga:notification:recipient | 154858456 | 31248 | |
| icinga:notification:user | 276544 | 154858456 | |
| icinga:notification:usergroup | 14785688 | 276544 | |
| icinga:notificationcommand | 2928 | 14785688 | |
| icinga:notificationcommand:envvar | 20494 | 2928 | |
| icinga:runtime | 600468848 | 21364 | |
| icinga:runtime:state | 946190028 | 380 | |
| icinga:schema | 1024 | 388 | |
| icinga:service | 58567219 | 4736 | |
| icinga:service:customvar | 64569712 | 55722854 | |
| icinga:service:state | 68522504 | 64569712 | |
| icinga:servicegroup | 7432 | 81322145 | |
| icinga:servicegroup:member | 1055632 | 8123 | |
| icinga:stats | 10880 | 1055632 | |
| icinga:timeperiod | 3627 | 10880 | |
| icinga:timeperiod:range | 11192 | 3524 | |
| icinga:user | 15448 | 11192 | |
| icinga:usergroup | 2536 | 15819 | |
| icinga:usergroup:member | 5264 | 2536 | |
| icinga:zone | 643040 | 5264 | |
| icingadb:overdue:service | 14200 | 643040 | |
| icingadb:telemetry:heartbeat | 4752 | 4752 | |
| icingadb:telemetry:stats | 24088 | 37424 |
I’m wondering if theres an issue here, or the secondary is just holding more data than the primary for “reasons”, or if its somehow misbalanced and the secondary is just doing more work.
I’d have expected that once things get written out to the DB, it would remove them from Redis.
Can anyone advise on the reason for the difference?
- Icinga DB Web version (System - About): 1.1.3
- Icinga DB Redis version: 7.2.6
- Icinga Web 2 version (System - About): 2.12.2
- Web browser: Safari
- Icinga 2 version (
icinga2 --version): r2.14.3-1 - Icinga DB version (
icingadb --version): v1.2.0 - PHP version used (
php --version): 8.2.28 - Server operating system and version: Debian 12
