I have several variables for the hosts, the value of which should not be displayed. Before ICINGADb, for example, passwords were displayed with ***.
I looked at the page Security - Icinga DB Web and no variation brought the success.
The variable is below “host.vars.ILO_PASSWORD”
If I enter this under “icingadb/denylist/variables” the rule takes effect and the variable disappears. Why doesn’t this work with “icingadb/protect/variables”?
Icinga DB Web version (System - About):
Icinga Web 2 version (System - About): 2.12.0
Web browser: Chrone / Edge / FireFox actual version
First of all… I’m pretty sure that before 1.1.0 the rule worked. After updating to I also had a problem with other existing rules. I had also posted a ticket for this, where I was then informed that the RegExp had changed.
By coincidence, I noticed this with the “Protected Vars”.
The user I’m testing with only has access to one host group.
I have created a role “1_Remove_Variable_Rule” where I define the variables that should not be displayed. I enter these roles in every other role. That’s how it’s always worked.
Yes, we are using 1.1.0 and “icingadb/denylist/variables” also works.
Here are the screenshots
