I am using icingadb RC2 in my environment. As I know from icinga2 with ido-mysql and icingaweb2 monitoring module: I can configure notification_icingaweb2url in notification template to get icingaweb2 link in email notifications. But with icingadb I get the icingaweb2 link referencing to the monitoring module, but I use the icingadb module instead of the monitoring module. What can I change to get the correct link?
Icinga DB Web version (1.0.0-rc2):
Icinga Web 2 version (2.9.6):
Web browser: Chrome
Icinga 2 version (r2.13.3-1):
Icinga DB version (v1.0.0-rc2-dev):
PHP version used (7.4.28):
Server operating system and version: Debian 11 (Icingaweb2 is running in docker)
You could change them, they’re probably located here: /etc/icinga2/scripts/
For hosts it should be: $ICINGAWEB2URL/icingadb/host?name=$(urlencode "$HOSTNAME")"
For services: $ICINGAWEB2URL/icingadb/service?host.name=$(urlencode "$HOSTNAME")&name=$(urlencode "$SERVICENAME")"
Please also open an issue over at Github so that this can be influenced by configuration, maybe.
Hey there
If your topic is resolved, please also make sure to mark the response that helped you solve it as the “solution” by clicking the three dots on that message.
