Hi guys,
My Icinga says that the database is not running or that it can’t read now, I just don’t know how to check if it can read or not, but it should be on, I used the command “systemctl enable --now icingadb”.
try
systemctl status icingadb
it seems that the config for the icingadb service is not correct:
https://icinga.com/docs/icinga-db/latest/doc/03-Configuration/#configuration
/etc/icingadb/config.yml
Thanks, it works after I have entered the password
