IcingaDB "empty" parent menu entry does not work
What I want to achieve
I want to create a parent menu entry that points to an overview of sub menu entries. Like this:
What’s the problem?
When I create such a parent entry with “no URL” (empty field “url”), I get an error message:
The URL in this case is “https:///icingaweb2/navigation/dashboard?name=filter-library”
The Nav-Item looks like:
Why do I expect this should work?
With the old “monitoring” module, this was not a problem and worked as expected.
This is an already reported bug: Error during opening a navigation root item · Issue #5177 · Icinga/icingaweb2 · GitHub
Thanks, didn’t expect such a ‘fundamental’ thing being open for so long (an didn’t look for open issues)
