The IcingaDB configuration mentions that history data can be deleted: Configuration - Icinga DB
This works as expected, but I am wondering, why the “history” table is not cleaned by the configuration. At the moment, it is 500MB in size - after 4 months of usage. And we do not need this history data.
# Retention is an optional feature to limit the number of days that historical data is available,
# as no historical data is deleted by default.
retention:
# Number of days to retain full historical data. By default, historical data is retained forever.
history-days: 30
# Number of days to retain historical data for SLA reporting. By default, it is retained forever.
sla-days: 30
# Map of history category to number of days to retain its data in order to
# enable retention only for specific categories or to
# override the number that has been configured in history-days.
options:
# acknowledgement:
# comment:
# downtime:
# flapping:
# notification:
# state:
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: Starting history retention
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category acknowledgement
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category comment
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category downtime
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category flapping
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category notification
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category state
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category sla_downtime
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Starting history retention for category sla_state
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category sla_state from table sla_history_state older than 2024-09-24 14:01:44.491232117 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: config-sync: Finished initial state sync in 466.494887ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: Starting state runtime updates sync
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: runtime-updates: Syncing runtime updates of HostState
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: runtime-updates: Syncing runtime updates of ServiceState
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category acknowledgement from table acknowledgement_history older than 2024-09-24 14:01:44.492486466 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category comment from table comment_history older than 2024-09-24 14:01:44.492510422 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category downtime from table downtime_history older than 2024-09-24 14:01:44.492601616 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category flapping from table flapping_history older than 2024-09-24 14:01:44.492614836 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: runtime-updates: Syncing runtime updates of Customvar
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: runtime-updates: Syncing runtime updates of CustomvarFlat
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category notification from table notification_history older than 2024-09-24 14:01:44.492627335 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category state from table state_history older than 2024-09-24 14:01:44.492642931 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: retention: Cleaning up historical data for category sla_downtime from table sla_history_downtime older than 2024-09-24 14:01:44.49265397 +0000 UTC
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM sla_history_state WHERE environment_id = :environment_id AND event_time < :time\nORDER BY event_time LIMIT 5000" with 0 rows in 3.39099ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM acknowledgement_history WHERE environment_id = :environment_id AND clear_time < :time\nORDER BY clear_time LIMIT 5000" with 0 rows in 2.881939ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM comment_history WHERE environment_id = :environment_id AND remove_time < :time\nORDER BY remove_time LIMIT 5000" with 0 rows in 2.95242ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM downtime_history WHERE environment_id = :environment_id AND end_time < :time\nORDER BY end_time LIMIT 5000" with 0 rows in 2.915408ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM flapping_history WHERE environment_id = :environment_id AND end_time < :time\nORDER BY end_time LIMIT 5000" with 0 rows in 3.606936ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM sla_history_downtime WHERE environment_id = :environment_id AND downtime_end < :time\nORDER BY downtime_end LIMIT 5000" with 0 rows in 11.063588ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM notification_history WHERE environment_id = :environment_id AND send_time < :time\nORDER BY send_time LIMIT 5000" with 0 rows in 11.618811ms
Oct 24 14:01:44 icinga0.cloud.nospamproxy.com icingadb[1382592]: database: Finished executing "DELETE FROM state_history WHERE environment_id = :environment_id AND event_time < :time\nORDER BY event_time LIMIT 5000" with 0 rows in 14.22041ms
- Icinga DB Web version (System - About):
- Icinga Web 2 version (System - About): 2.12.1
- Web browser: Edge
- Icinga 2 version (
icinga2 --version): r2.14.2-1 - Icinga DB version (
icingadb --version): 1.1.3 - PHP version used (
php --version): PHP 8.1.2-1ubuntu2.19 - Server operating system and version: Ubuntu 24.04
