Steps to recreate:
- Create a set of TLS certificates for Redis and IcingaDB, place them in ‘.ssl’
- Create Redis configuration
# /etc/redis.conf
bind 0.0.0.0
protected-mode no
port 0
loglevel notice
tls-port 6379
tls-cert-file /usr/local/etc/redis/ssl/redis.pem
tls-key-file /usr/local/etc/redis/ssl/redis-key.pem
tls-ca-cert-file /usr/local/etc/redis/ssl/allcacerts.pem
proc-title-template "{title} {listen-addr} {server-mode}"
- Create Redis service container
docker run --rm -d \
-v ./ssl:/data/ssl/ \
-v /etc/redis.conf:/usr/local/etc/redis/redis.conf \
-p 6379:6379 \
--name redis \
-h redis04 \
redis:alpine3.15 \
redis-server /usr/local/etc/redis/redis.conf
- Create IcingaDB configuration
# /etc/icingadb/config.yml
database:
type: mysql
host: mysql04
port: 3306
database: icingadb
user: icinga
password: T3stCred$
redis:
address: redis04:6379
tls: true
cert: /data/ssl/icinga.pem
key: /data/ssl/icinga-key.pem
ca: /data/ssl/allcacerts.pem
logging:
level: debug
output: console
history-retention:
days: 2
options:
- Following the Installation Instructions, get the repo (Ubuntu) key
wget -O /data/icingadb/icinga.key https://packages.icinga.com/icinga.key
echo "deb https://packages.icinga.com/ubuntu icinga-focal-testing main" > /data/icingadb/focal-icinga-testing.list
- The IcingaDB Dockerfile
# /data/icingadb.Dockerfile
FROM ubuntu:focal AS focal-b
RUN apt update;\
apt -y install apt-utils apt-transport-https wget gnupg;\
apt clean
ADD focal-icinga-testing.list /etc/apt/sources.list.d/focal-icinga-testing.list
ADD icinga.key icinga.key
RUN apt-key add icinga.key;\
apt update
FROM focal-b AS focal-icingadb
RUN mkdir /etc/icingadb
RUN chown -vR 101:101 /etc/icingadb
RUN apt install --no-install-recommends -y icingadb;\
apt clean
CMD ["icingadb", "--config", "/etc/icingadb/config.yml"]
- Build the Dockerfile image
docker build /data/icingadb -f /data/icingadb/icingadb.Dockerfile -t focal-icingadb
- Run the IcingaDB container
docker run --rm \
-v /data/icingadb/config.yml:/etc/icingadb/config.yml \
-v .ssl:/data/ssl/ \
focal-icingadb:latest \
icingadb -c /etc/icingadb/config.yml
The container will start but then will exit with the following errors
2022-05-01T00:50:47.543Z INFO icingadb Starting Icinga DB
2022-05-01T00:50:47.543Z INFO icingadb Connecting to database
2022-05-01T00:50:47.554Z INFO icingadb Connecting to Redis
2022-05-01T00:50:55.758Z FATAL icingadb read tcp 172.19.0.4:36988->172.19.0.2:6379: read: connection reset by peer
can't connect to Redis
main.run
/builds/packaging/deb-icingadb/build/icingadb/cmd/icingadb/main.go:83
main.main
/builds/packaging/deb-icingadb/build/icingadb/cmd/icingadb/main.go:34
runtime.main
/usr/local/go/src/runtime/proc.go:225
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1371
According to the Redis service container, there is disagreement about how SSL is processed
docker logs -n 10 redis04
1:M 01 May 2022 00:50:53.695 # Error accepting a client connection: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
1:M 01 May 2022 00:50:54.209 # Error accepting a client connection: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
1:M 01 May 2022 00:50:54.725 # Error accepting a client connection: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
And yet when confirmed (using the IcingaDB set of TLS certificates) Redis is properly configured and functioning
docker run --rm \
redis:alpine3.15 \
redis-cli --tls \
--cert /data/ssl/icinga.pem \
--key /data/ssl/icinga-key.pem \
--cacert /data/ssl/allcacerts.pem \
-h redis04 SET last 04-29-2022_1552
OK
docker run --rm \
redis:alpine3.15 \
redis-cli --tls \
-h redis04 GET last
04-29-2022_1552
The idea was to get around the current IcingaDB docker TLS issue, but even this method proven illusive. Short of using Redis without TLS for IcingaDB (not desirable, even for development) are there any other options?
