I a fresh installed Icinga2 based on IcingaDB and Director.
Now I want to visualize my outputs in graphs, to see some up and downs from service results over the day/week/month…
What is the best and easiest module to install that based on IcingaDB? I dont want to have something like grafana, that I have to switch to another browser-page. I want that for every host/service.
Maybe someone knows something and has may a installation tutorial for that. The internet is full of that but most is for monitoring module…
I would still have Graphite on offer as a suggestion. However, Graphite has its own web interface just like Grafana. By the way, you can view Grafana directly in Icinga and also change the times in Icinga.
If I want to read out my Grafana I do this mostly directly via Icinga2 and not via the Grafana webinterface.
I´m currently using Icingaweb2 with InfluxDB and the Grafana-Plugin, but I don´t know whether the plugin works with IcingaDB.
Within Icinga I use “Standard” checks like ping for the hosts and for other tasks I use dashboards inside Grafana.
Hope this helps
