Hello together,
I upgraded PHP version from rh-php71 to rh-php72 and after that i just removed the old version. Everything works fine exept icingacli which complained, see bellow.
icingacli: sh: /usr/bin/icingacli: /opt/rh/rh-php71/root/usr/bin/php: bad interpreter: No such file or directory
I used a workaround and created symlink from /opt/rh/rh-php71/root/usr/bin/php to /opt/rh/rh-php72/root/usr/bin/php. And it works, but I would like to prefer change configuration of icingacli that use the new version directly. No symlinks. Unfortunatelly I hadn’t luck to find where it is set.
Could you help me please? Thanks a lot in advance.
