Hi all,
I just compiled apache and php-fpm on my server (debian stable).
Installed icinga2 (debian package) and icinaweb2 (by hand) without problem, everything is running fine.
The problem I have now is when running icingacli, it throws this message:
PHP Warning: require_once(/usr/library/Icinga/Application/Cli.php): Failed to open stream: No such file or directory in /usr/bin/icingacli on line 5
PHP Fatal error: Uncaught Error: Failed opening required '/usr/library/Icinga/Application/Cli.php' (include_path='.:') in /usr/bin/icingacli:5
Stack trace:
#0 {main}
thrown in /usr/bin/icingacli on line 5
My icingaweb2 is installed in /var/www/icingaweb2/ and it looks like the DIR variable is wrongly defined somewhere.
Any idea on that?
Thanks in advance
PHP version 8.1.15
Apache version 2.4.55
Icinga2 version 2.13.6
icingaweb2 version 2.9.5
