Icinga2 v.r2.14.2-1 with Apache v2.4.62
With the latest Apache version of 2.4.62, if upgraded, will this break compatibility with the version of icinga we are currently running based on the below details?
Thank you.
  • Version used: r2.14.2-1
  • Operating System and version:
    Distributor ID: Ubuntu
    Description: Ubuntu 20.04.6 LTS
    Release: 20.04
    Codename: focal
  • Icinga Web 2 version and modules: Grafana 2.0.3, monitoring 2.12.1, icingadb 1.1.2
don’t think so, but you should update to 2.14.3
here some background:
  • icinga2 has nothing to do with apache
  • icingaweb2 is hosted via apache or nginx and I can’t think of any problems here
  • icingaweb2 uses php, i don’t want to look it up but not every subversion of icingaweb2 works with every version of php
