hi all
UPDATE:
I’ve figured out that this problem only appears when we add more then 1 vCPU to the VM.
with 1 cpu all version works as expected.
with 2+ vcpu it crashes frequently…
We have an icinga2 instance running on Ubuntu Linux (it’s a VM on a proxmox machine)
we have about 75+ hosts with 1000+ services.
our problem is that icinga2 randomly crashes on startups.
We have tried to
-upgrade OS from 16.04->18.04->19.04
-upgrade icinga2 from 2.8->2.9->2.10->2.11
-build a new machine from scratch (18.04) and install a fresh icinga2 on it
no changes. we get random errors. sometimes it manages to start up, then it runs correctly but the more hosts we add the bigger the chance of failure.
if we run 0 hosts it starts up correctly, with ~10 hosts it usually works okay, but with more, it usually fails.
So once again, sometimes it starts up (even with full host list), so I guess the configs are okay, it’s not complaining about config errors, only showing lowlevel system errors are when failing.
I appreciate your help cause this drives me crazy.
here are some of the random error messages - they are different almost every time
[2019-10-03 18:31:41 +0200] information/cli: Icinga application loader (version: r2.11.0-1)
[2019-10-03 18:31:41 +0200] information/cli: Loading configuration file(s).
[2019-10-03 18:31:41 +0200] information/ConfigItem: Committing config item(s).
corrupted size vs. prev_size while consolidating
/builds/packaging/deb-icinga2/build/icinga2/lib/base/json.cpp:185: assertion failed: !“Invalid variant type.”
[2019-10-03 18:31:40 +0200] information/cli: Icinga application loader (version: r2.11.0-1)
[2019-10-03 18:31:40 +0200] information/cli: Loading configuration file(s).
[2019-10-03 18:31:40 +0200] information/ConfigItem: Committing config item(s).
double free or corruption (out)
Caught SIGABRT.
[2019-10-03 18:31:39 +0200] information/cli: Icinga application loader (version: r2.11.0-1)
[2019-10-03 18:31:39 +0200] information/cli: Loading configuration file(s).
[2019-10-03 18:31:39 +0200] information/ConfigItem: Committing config item(s).
[2019-10-03 18:31:38 +0200] information/cli: Icinga application loader (version: r2.11.0-1)
[2019-10-03 18:31:38 +0200] information/cli: Loading configuration file(s).
[2019-10-03 18:31:38 +0200] information/ConfigItem: Committing config item(s).
Caught SIGABRT.
Current time: 2019-10-03 18:31:38 +0200
[2019-10-03 18:31:38 +0200] critical/Application: Icinga 2 has terminated unexpectedly. Additional information can be found in ‘/var/log/icinga2/crash/report.1570120298.494978’
free(): invalid pointer
- content of a crash log:
Application version: r2.11.0-1
System information:
Platform: Ubuntu
Platform version: 19.04 (Disco Dingo)
Kernel: Linux
Kernel version: 5.0.0-29-generic
Architecture: x86_64
Build information:
Compiler: GNU 8.3.0
Build host: runner-LTrJQZ9N-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Stacktrace:
(0) libc.so.6: gsignal (+0xc7) [0x7f147fbeaed7]
(1) libc.so.6: abort (+0x121) [0x7f147fbcc535]
(2) libc.so.6: <unknown function> (+0x8c726) [0x7f147fc33726]
(3) libc.so.6: <unknown function> (+0x9359a) [0x7f147fc3a59a]
(4) libc.so.6: <unknown function> (+0x953dc) [0x7f147fc3c3dc]
(5) icinga2: <unknown function> (+0x67b16d) [0x55c8ce8a516d]
(6) icinga2: icinga::ApplyRule::AddRule(icinga::String const&, icinga::String const&, icinga::String const&, std::shared_ptr<icinga::Expression> const&, std::shared_ptr<icinga::Expression>
const&, icinga::String const&, icinga::String const&, icinga::String const&, std::shared_ptricinga::Expression const&, bool, icinga::DebugInfo const&, boost::intrusive_ptricinga::Dictionary con
st&) (+0x78f) [0x55c8ce8b0e7f]
(7) icinga2: icinga::ApplyExpression::DoEvaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0x15f) [0x55c8ce89ee1f]
(8) icinga2: icinga::Expression::Evaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0x53) [0x55c8ce8a9c73]
(9) icinga2: icinga::DictExpression::DoEvaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0xd1) [0x55c8ce8acd01]
(10) icinga2: (+0x750382) [0x55c8ce97a382]
(11) icinga2: icinga::Expression::Evaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0x53) [0x55c8ce8a9c73]
(12) icinga2: icinga::DictExpression::DoEvaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0xd1) [0x55c8ce8acd01]
(13) icinga2: icinga::Expression::Evaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0x53) [0x55c8ce8a9c73]
(14) icinga2: icinga::DictExpression::DoEvaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0xd1) [0x55c8ce8acd01]
(15) icinga2: icinga::Expression::Evaluate(icinga::ScriptFrame&, icinga::DebugHint*) const (+0x53) [0x55c8ce8a9c73]
