Icinga2 pgsql.sql missing
Hoping for help here.
During the installation of Icinga2, exactly the phase of installing PostgreSQL on the server, I came across an error
when executing the command:
sudo -u icinga -d icinga < /usr/share/icinga2-ido-pgsql/schema/pgsql.sql
the error:
-bash: /usr/share/icinga2-ido-pgsql/schema/pgsql.sql: No such file or directory
I am following this guide: Ubuntu - Icinga 2
PostgreSQL on the server, I came across an error when executing the
command:
sudo -u jwansulyman -d icinga < /usr/share/icinga2-ido-pgsql/schema/pgsql.sql
I do not see that command shown in the following instructions:
Ubuntu - Icinga 2
Do you perhaps instead mean this command?
psql -U icinga -d icinga < /usr/share/icinga2-ido-pgsql/schema/pgsql.sql
Also, what is the output of ā€œapt-cache policy icinga2-ido-pgsqlā€?
Antony.
Yes, the user icinga was meant. I executed the command and got the info that icinga2-ido-mysql is not installed. So I did that from apt and tried again.
I got prompted to enter a password:
Password for user icinga:
psql: error: FATAL:  password authentication failed for user "icinga"
and it failed, because I can’t remember setting up a password for this user :slight_smile:
  1. What is the output of ā€œapt-cache policy icinga2-ido-pgsqlā€?
  2. Did you perform the steps:
cd /tmp
sudo -u postgres psql -c ā€œCREATE ROLE icinga WITH LOGIN PASSWORD ā€˜icingaā€™ā€
sudo -u postgres createdb -O icinga -E UTF8 icinga
Antony.
Thank you for helping out!
Yes, these commands work. However instead of the second one, I executed:
psql -U icinga -d postgres -h 127.0.0.1 -W
icinga: role created
postgres: the database
