Has anyone any experience with installing Icinga2 on Scientific Linux? I have an issue with installing Icingaweb2, especially with the rh-php package dependencies.
Try installing these, rh-php73-php-mysqlnd, sclo-php73-php-pecl-imagick and rh-php73-php-fpm
from SCL and Epel repos. I installed the rest of php74 from remi.
It may be worth considering using a container (Docker, podman) for icingaweb2. Depending on your comfort level and other requirements it’s hard to say what the best path forward for you would be.
Thanks for the idea. Unfortunately I’m not familiar with container technologies and I don’t have any Docker environment. But, maybe it’s time to start to deal with it
Hmm, not sure. Here is how I started my install on CentOS 7.9. Scientific Linux is no longer being maintained, may want to try CentOS7. But then again CentOS(8) was dropped from RedHat, it is been changed to CentOS Stream. Anyway, that is another story. We are still scrambling trying to figure out what will be the next OS.
