I’m running icinga2 in HA setup. After DB server (postgresql) server crash icinga2 daemon is unable to write to the DB.
IDO connection: ido-pgsql
qlConnection, ido-pgsql) items: 2601, rate: 0/s (0/min 0/5min 0/15min); empty in 9 seconds
qlConnection, ido-pgsql) items: 3614, rate: 0/s (0/min 0/5min 0/15min); empty in 35 seconds
qlConnection, ido-pgsql) items: 4843, rate: 0/s (0/min 0/5min 0/15min); empty in 39 seconds
qlConnection, ido-pgsql) items: 5844, rate: 0/s (0/min 0/5min 0/15min); empty in 58 seconds
qlConnection, ido-pgsql) items: 6917, rate: 0/s (0/min 0/5min 0/15min); empty in 1 minute and 4 seconds
qlConnection, ido-pgsql) items: 7584, rate: 0/s (0/min 0/5min 0/15min); empty in 1 minute and 53 seconds
qlConnection, ido-pgsql) items: 7985, rate: 0/s (0/min 0/5min 0/15min); empty in 3 minutes and 19 seconds
qlConnection, ido-pgsql) items: 8462, rate: 0/s (0/min 0/5min 0/15min); empty in 2 minutes and 57 seconds
qlConnection, ido-pgsql) items: 8929, rate: 0/s (0/min 0/5min 0/15min); empty in 3 minutes and 11 seconds
qlConnection, ido-pgsql) items: 9308, rate: 0/s (0/min 0/5min 0/15min); empty in 4 minutes and 5 seconds
qlConnection, ido-pgsql) items: 9725, rate: 0/s (0/min 0/5min 0/15min); empty in 3 minutes and 53 seconds
qlConnection, ido-pgsql) items: 10124, rate: 0/s (0/min 0/5min 0/15min); empty in 4 minutes and 13 seconds
qlConnection, ido-pgsql) items: 10487, rate: 0/s (0/min 0/5min 0/15min); empty in 4 minutes and 48 seconds
qlConnection, ido-pgsql) items: 10834, rate: 0/s (0/min 0/5min 0/15min); empty in 5 minutes and 12 seconds
qlConnection, ido-pgsql) items: 11183, rate: 0/s (0/min 0/5min 0/15min); empty in 5 minutes and 20 seconds
qlConnection, ido-pgsql) items: 11464, rate: 0/s (0/min 0/5min 0/15min); empty in 6 minutes and 47 seconds
qlConnection, ido-pgsql) items: 11921, rate: 0/s (0/min 0/5min 0/15min); empty in 4 minutes and 20 seconds
qlConnection, ido-pgsql) items: 12872, rate: 0/s (0/min 0/5min 0/15min); empty in 2 minutes and 15 seconds
The update time seems to be updated on master restart, but no other data (service updates) being written.
icinga2_data=# select status_update_time from icinga_programstatus;
status_update_time
2020-07-28 05:01:05
I don’t see any other errors in logs. The web interface says:
Monitoring backend 'backends' is not running.
