I am facing an issue with my Icinga2 after
apt update and apt upgrade
I cant start any Icinga service anymore and when I try to install or update only icinga2 package i get this error.
Any Ideas on this?
Error message
dpkg: error processing package icinga2-bin (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of icinga2-ido-mysql:
icinga2-ido-mysql depends on icinga2-bin (= 2.14.0-1+ubuntu20.04); however:
Package icinga2-bin is not configured yet.
icinga2-ido-mysql depends on icinga2-common (= 2.14.0-1+ubuntu20.04); however:
Package icinga2-common is not configured yet.
dpkg: error processing package icinga2-ido-mysql (–configure):
dpkg: dependency problems prevent configuration of icinga2:
icinga2 depends on icinga2-bin (= 2.14.0-1+ubuntu20.04); however:
Package icinga2-bin is not configured yet.No apport report written because the error message indicates its a followup error from a previous failure.
icinga2 depends on icinga2-common (= 2.14.0-1+ubuntu20.04); however:
dpkg: error processing package icinga2 (–configure):
No apport report written because MaxReports is reached already
Errors were encountered while processing:
icinga2-common
icinga2-bin
icinga2-ido-mysql
icinga2
E: Sub-process /usr/bin/dpkg returned an error code (1)
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.0-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 20.04.6 LTS (Focal Fossa)
Kernel: Linux
Kernel version: 5.15.0-1042-azure
Architecture: x86_64
Build information:
Compiler: GNU 9.4.0
OpenSSL version: OpenSSL 1.1.1f 31 Mar 2020
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
A new installation did nothing for me. My solution, since it is critical to the company, is to restore your backup. I am currently testing the fix in my Icinga2 test environment.
Sadly I dont have any backup, because I am in Test Environment.
But I think It would help to install and older Version of icinga2 to not face this issue.
If the issue was a circular dependency in the config then your system is already broken, you just may not know it yet. 2.14 does us a nice favor by detecting that and rejecting the config.
