Hi i’ve been trying to run the node wizard to connect nodes for monitoring, because the client is running a webserver that isnt compatible with icinga (icinga is hardcoded for a particular setup) and i dont want to disturb anything already running. So i set up icinga on a raspberry pi within LAN to monitor it. Everytime i try to connect them at the last step using the node wizard on the client i get:
critical/pki: Cannot connect to host ‘mydomain.com’ on port ‘5665’
critical/cli: Peer did not present a valid certificate.
I’ve been following the guides but so far it hasnt helped. Icingaweb2 is running well on the server (raspberry pi) and i checked that icinga2 is running as well with the port opened and port forwarded by the router.
So far icinga2 has been a 2 week headache, i’ve been trying to push for monitoring of load so we dont overfill a webserver but it has not gone well with management because of the current time its been taking to set it up. It would be much easier to have icinga web on the client but its not like i can make it use lsphp7.4 and litespeed that have been configured as the default httpd/php even via command line, it still wants its php packages and apache.
