i configured the Icinga2 Master on Debian.
i have the problem that all checks are late:
With the button “check now” the check works for one time.
Welcome to the community!
Please share more info about your setup and the affected services. Interesting are information regarding the icinga2 versions, failing checks, rendered host and service configuration for these checks, zones & satellite config if applicable, etc.
There are many things that could fail and cause this behavior. The provided info does not really allow a qualified support.
We battled with a similar problem for a long time, until we learnt that our dependency settings were wrong. Perhaps one possible cause. Check also that you have no downtimes set on that service…
P.S.: I assume you have the “checker” feature enabled?
Thanks for the answers.
i fixed it with the following things:
linux time/timezone and database time/timezone
changed wrong dependency settings
