I use Debian Strech
I have an Icinga2 on 2.6.2, after an upgrade my Icinga2 crash.
I reinstall IT.
icinga2 (2.10.4-1)
icingaweb2 (2.6.2-1)
I use a LDAP authentification, during configuration some account will be find, I select a account.
But when I try to connect I have a message for an incorrect user or password. But when I use this account with an another program, authentication is ok.
I have configure too
[logging]
log = “file”
level = “DEBUG”
file = “/var/log/icingaweb2/icingaweb2.log”
Okidoki, and a manual LDAP query with the provided credentials looks like? Maybe there’s something wrong with the details, and your other application differs.
I have rebooted, restarted, even removed and let the application recreate the log file, renamed the file through the application (which it does create it, just empty every time)…however nothing ever logs to it… I have also disabled selinux (Permissive mode) and still never seem to get content into the log file.
I have also check apache logs, nothing in access/error logs
I retract my previous issue… I did a test by inserting a bogus user/password to login and now I see content. So I have set the loglevel back to WARNING only.
Guessing there isn’t a lot of messages from icingaweb2 going on to begin with.
Sorry for the bother on this.
