It should be easy to integrate this one, into icinga2.
But I have to configure these two paths:
// Set these two lines - they are very important
// In linux run `updatedb` and `locate nagios.cfg` and `locate status.dat` to find these files
// They are usually placed in /usr/local/nagios/etc/nagios.cfg and /usr/local/nagios/var/status.dat
'cfg_file' => "x",
'status_file' => "x",
Where I can find these two files? I just installed icinga2 + icingaweb2. But they show just the example directory of the nagios paths, but I dont own nagios?
My idea is to create a map of my company to visible connections between switches in different buildings.
So may I need something with “parent” attributes, that I can open this map and see on a failure, which switch behind switch x is also offline, when switch x is broken.
Ok, then it is not the map module what you are looking for.
There is no solution for Icinga 2 to automatically visualize the dependencies as far as I know.
You could have a look into meerkat which is relative new and standalone or nagvis which can be integrated via a module but looks a bit old nowadays in my opinion. Both should be capable of what you want, but it will be some manual work.
