My question is simple: Is there, somewhere, some documentation for how Icinga2 work on the lowest level?
I remember, some years ago I set up monitoring and had a good understanding of how many of the concepts and objects worked together, and I think the documentation did more to explain where the config files were stored and how they were set up as text files. Now, however, there doesn’t seem to be so much of that - the docs I’ve found all seem to avoid the topic and steer you towards using some tools and commands, which is all very well, as long as everything goes perfectly, but when things don’t work, you have a hard time figuring out why.
So, are there instructions for setting up the configuration manually?
This is my icinga2 version:
root@vogon:/etc/icinga2/zones.d# icinga2 -V
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.6-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 11 (bullseye)
Kernel: Linux
Kernel version: 5.10.0-13-amd64
Architecture: x86_64
Build information:
Compiler: GNU 10.2.1
OpenSSL version: OpenSSL 1.1.1n 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
