A quick overview what I did from the original icinga2 documentation:
Installed basic Icinga2 package on master1 + master2 with monitoring-plugins
Installed icingadb-redis (changed listening interface + protected mode to “no” on both masters
Installed icingadb and enabled feature on both masters
Installed mariadb-server on server ic-mariadb (act as database server and test client/agent for checks in this setup) and imported icinga-schema [created a database for icingadb, icingaweb and director]
Installed icingadb-web package on both masters
Configured both masters web-setup (…/icingaweb2/setup) entered on both the icingadb database, the same icingaweb database for authentication. Entered on both servers the redis primary server the ic-master1.lab.nk and as secondery on both the second one (may wrong?!), entered for each command-transport there own local api-user (right?!)
Both web installers runs accross with no errors. Works fine. Both websites shown pre-defined icinga2 checks on ic-master1.lab.nk. Login with same user works.
Installed icinga-director package module on ic-master1.nk.lab via apt. Configured director with database and did the first deployment without errors.
Now the step where I’m lost:
Created a host- and service template. Created the host “ic-mariadb.nk.lab” and added a “icinga2” agent check for the host. Now I see this check two times on each webinterface. So its because both nodes looks into the same database? If I shutdown the master1, the check cant be executed manually from master2 interface because of missing permissions?!..
For high-availability setups, it is a good idea to enable the Icinga DB feature on the secondary master after you have successfully connected from/to the primary master so that the certificates are set up properly. The secondary master will then generate the same environment ID since it is working with the same CA certificate.
In any case make sure that the file /var/lib/icinga2/icingadb.env does not change over time and is the same on all Icinga 2 master nodes per environment.
copy them from the primary master/ config master to the other machine and restart icinga2.
I deleted the database on my db-server and created it new and imported the schema.
Recreated host & service via director, works! I see the service-object now only one time on both dashboards of the masters.
Check-Scheduler was master1, I powered off master1, check-scheduler changed instantly to master2. Can view results on masters2 dashboard while master1 is offline.
Next little problem:
If I want to manually use the button “Check now” from masters2 dashboard, I get this error-message (check result is every 10s updated and works):
On both root with * permission but each master has a unique generated password.
Should be also the same?
If so, what is the option in the director → icinga infrastucture → endpoints → “api user” field? Should I enter the details in the director for the both masters or in the local file that u called?
