I have a HA master-master pair, and the active endpoint is refusing to send some notifications. It will send my slack and email notifications, but will not send the SMS ones. It generate the following error in the debug log
[2021-07-12 14:51:32 -0400] notice/Notification: Notification 'ca04vlgraylogweb01!check_graylog_events_mercury!sms-escalation': HA cluster active, this endpoint does not have the authority (paused=true). Skipping.
This seems odd to me since that host the error is generated on is the active endpoint.
Notes: the notification feature is only enabled on the active endpoint (host1 ) and is not enabled on host2. because of a related issue: Icinga2 crashes when sending notifications · Issue #8186 · Icinga/icinga2 · GitHub
Can anyone help me figure out why the active endpoint (which is also the config master), wont send SMS notifications (ie escalation)? Even though it is the active endpoint and is the host writing to IDO.
- Version used
icinga2 - The Icinga 2 network monitoring daemon (version: r2.12.4-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
Platform: Ubuntu
Platform version: 20.04.2 LTS (Focal Fossa)
Kernel: Linux
Kernel version: 5.8.0-1038-aws
Architecture: x86_64
Build information:
Compiler: GNU 9.3.0
Build host: runner-hh8q3bz2-project-298-concurrent-0
OpenSSL version: OpenSSL 1.1.1f 31 Mar 2020
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Operating System and version
Ubuntu 20.04.2 LTS (Focal Fossa)
- Enabled features (
icinga2 feature list
host 2
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb livestatus notification opentsdb perfdata statusdata syslog
Enabled features: api checker ido-mysql influxdb mainlog
host 1 (config master)
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker ido-mysql influxdb mainlog notification
- Icinga Web 2 version and modules (System - About)
Name Version
setup 2.9.0
grafana 1.4.2
monitoring 2.9.0
Icinga Web 2 Version
2.9.0
Git commit
3b0a0a78df9389c46d3a74611a8eaec2f2b3cc77
PHP Version
7.4.21
Git commit date
2021-07-12
Copyright
© 2013-2021 Icinga GmbH
- Config validation (
icinga2 daemon -C
[2021-07-14 12:09:51 -0400] information/cli: Icinga application loader (version: r2.12.4-1)
[2021-07-14 12:09:51 -0400] information/cli: Loading configuration file(s).
[2021-07-14 12:09:52 -0400] information/ConfigItem: Committing config item(s).
[2021-07-14 12:09:52 -0400] information/ApiListener: My API identity: host1.internal
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 NotificationComponent.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 238 Hosts.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 10 Downtimes.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 5 NotificationCommands.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 FileLogger.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 102 Comments.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 13054 Notifications.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 IcingaApplication.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 22 HostGroups.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 CheckerComponent.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 235 Zones.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 235 Endpoints.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 3 ApiUsers.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 ApiListener.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 116 CheckCommands.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 1 InfluxdbWriter.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 7 TimePeriods.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 9 UserGroups.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 11 Users.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 4019 Services.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 9 ServiceGroups.
[2021-07-14 12:09:54 -0400] information/ConfigItem: Instantiated 10 ScheduledDowntimes.
[2021-07-14 12:09:55 -0400] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2021-07-14 12:09:55 -0400] information/cli: Finished validating the configuration file(s).
- If you run multiple Icinga 2 instances, the
zones.conf
file (oricinga2 object list --type Endpoint
andicinga2 object list --type Zone
) from all affected nodes
/* THIS FILE IS MANAGED BY PUPPET.*/
object Endpoint "host1.internal" {
object Endpoint "host2.internal" {
host = "10.4.10.41"
object Zone "master" {
endpoints = [ "host1.internal","host2.internal" ]
global = true
host2
global = true
