Am setting up a new icinga cluster with HA (2 icinga masters).
Master-a: /etc/icinga2/zones.conf:
object Endpoint "55i.icingapoc" {
object Endpoint "55j.icingapoc" {
object Zone "master" {
endpoints = [ "55i.icingapoc", "55j.icingapoc" ]
global = true
global = true
Master-b: /etc/icinga2/zones.conf:
host = "192.168.100.4"
port = "5665"
global = true
global = true
Am facing a probleme. As i created a new satellite zone on Master-a and a new zone directory in “zones .d” caled “cluster1” this dir and all the zone configuration (hosts, hostgroupes, endpoints …) in it is not replicated on the second master (Master-b)
/* Satellite1 */
object Endpoint "monitoring1.cluster1.test" {
object Endpoint "monitoring2.cluster1.test" {
object Zone "cluster1" {
parent = "master"
endpoints = [ "monitoring1.cluster1.test",
"monitoring2.cluster1.test" ]
Master-a:
# ls -lrta /etc/icinga2/zones.d/
total 4
drwxr-xr-x. 2 icinga icinga 110 17 juin 03:06 master
drwxr-xr-x. 2 icinga icinga 96 17 juin 04:00 cluster1
drwxr-xr-x. 2 icinga icinga 48 17 juin 04:01 global-templates
drwxr-x---. 5 icinga icinga 74 17 juin 04:01 .
drwxr-x---. 7 icinga icinga 235 17 juin 04:08 ..
Master-b:
# ls -lrta /var/lib/icinga2/api/zones
total 0
drwx------. 3 icinga icinga 54 17 juin 04:02 global-templates
drwx------. 3 icinga icinga 54 17 juin 04:02 master
drwx------. 4 icinga icinga 44 17 juin 04:02 .
drwxr-x---. 6 icinga icinga 165 17 juin 04:02 ..
Is this normal?
If yes, how das the second muster (Master-b) get the child zones configuration so it can diribute it to the satelites incase the first master fails.
what can i do to make the 2 masters sync all the config?
Please help.
And thanks in advance.
