yep, that’s a known and wanted behaviour. Each endpoint can elect the active zone endpoint without actually knowing much about the other one, except for being connected. It’s more of an internal algorithm, and you shouldn’t care much - the more important part is that on either side’s failure, your monitoring continues with checks and notifications. And that’s obviously the case
Thanks for your response. And sorry for asking obvious things that appear in documentation. I have read almost all the documentation but it is evident that not with the tranquility that I needed.
no worries - while we strive to improve also the technical concepts in the docs, it always helps to ask and clear things up. Others will likely find your question via Google, and it then helps even more
