Icinga2 Graphite - purge old data - Maintenance
I have followed this documentation https://www.trash.co.nz/2018/11/icinga2-graph-data-retention/ for setting up he graphite data retention… current configuration is
[carbon]
pattern = ^carbon.
retentions = 10s:6h,1m:1w,15m:1y
[default_1min_for_1day]
pattern = .*
retentions = 10s:6h,1m:6d,10m:1800d
I still have few gaps to maintain the graphite data… We have around 120 hosts & we have created separate mount point that is around 200G. right now this is 65% filled… I would like to understand how to maintain graphite data… is something i need to schedule cron job to clean the data which is older than 7 days? i am little scared to purge any graphite data…
I am trying to do this https://sysadmin.compxtreme.ro/clean-up-whisper-database/
Can you please advise the which is the best way to maintain graphite data & we don’t want file system filled 100%…
So when whisper files are created by the carbon cache daemon, they claim all the disk size they need. That is, if you tell a metric to retain 1,800 days worth of data, it creates a file large enough to fit all of that data into.
The second link you provided is basically a good way to remove metrics that are obsolete; service checks you’ve removed from Icinga.
If you want less retentions for existing Graphite data, look into the whisper-resize script that comes with it. Be careful though, this irreversibly changes these files.
/usr/local/bin/whisper-resize.py --help
Usage: whisper-resize.py path timePerPoint:timeToStore [timePerPoint:timeToStore]*
timePerPoint and timeToStore specify lengths of time, for example:
60:1440      60 seconds per datapoint, 1440 datapoints = 1 day of retention
15m:8        15 minutes per datapoint, 8 datapoints = 2 hours of retention
1h:7d        1 hour per datapoint, 7 days of retention
12h:2y       12 hours per datapoint, 2 years of retention
Options:
  -h, --help            show this help message and exit
  --xFilesFactor=XFILESFACTOR
                        Change the xFilesFactor
  --aggregationMethod=AGGREGATIONMETHOD
                        Change the aggregation function (average, sum, last,
                        max, min, avg_zero, absmax, absmin)
  --force               Perform a destructive change
  --newfile=NEWFILE     Create a new database file without removing the
                        existing one
  --nobackup            Delete the .bak file after successful execution
  --aggregate           Try to aggregate the values to fit the new archive
                        better. Note that this will make things slower and use
                        more memory.
It it also helpful to find/ delete files that have not changed or empty.
find /var/lib/graphite/whisper/icinga2/ -type f -name *.wsp -mtime +30 -delete
find /var/lib/graphite/whisper/icinga2/ -type d -empty -delete
