Icinga2 graphite graph dissapear from Icinga when auto refresher enabled
Icinga auto refresher makes integrated graphite graph dissapear after it refreshes. This happens when i change timeline from default to other custom time.
I confirmed this by disabling auto refresher, then the graph stayed and didn’t dissapear.
I also confirmed with changing auto refresher speed to slow, then it stayed longer, but dissapeared after longer time.
Interesting is that it dissapears only when timeline is changed from default, if left default it doesn’t dissapear.
I also tried different versions of graphite icinga module. From version 1.1.0 till latest 1.2.3.
Same problem.
  • Icinga Web 2 Version 2.11.4
  • icinga/icinga-php-thirdparty 0.11.0
  • icinga/icinga-php-library 0.12.0
  • Icinga version - 2.13.2-1
  • AlmaLinux release 8.8 (Sapphire Caracal)
  • graphite 1.2.3
  • PHP 8.0.30
That’s a known bug. Though, you can circumvent it by clicking the empty space somewhere in the detail, which will remove the focus (the outline, as seen in your 2nd screenshot) from the control.
Thank you Johannes, that is true. Just tested and it appears again. Since it is partial solution, there probably isn’t any permanent solution till this day?
I also raised issue on github about this bug:
