We have been using Icinga2 for windows systems with Icinga2 agent, NSClient & Powersell for windows.
Not suddenly we started adding the linux servers… Our instances are aws ec2 instances in private subnets & those are not integrated with Active Directory… I have installed icinga2 agent on those boxes but no luck… Still not working with icinga2 metrics like load/memory/procs etc… Can someone help the best way to monitor the linux hosts? we are looking for basic infra monitoring like cpu,memory,service & procs check etc…
Just to add here… Our linux servers are not added to active directory… Those are aws ec2 instances…
root@aws-**-02:/home/ubuntu# icinga2 node wizard
Please specify if this is an agent/satellite setup ('n' installs a master setup) [Y/n]: y
Starting the Agent/Satellite setup routine...
Please specify the common name (CN) [aws-***-02]: <Privided the private ip address>
Master/Satellite Common Name (CN from your master/satellite node): <Master icinga2 server name>
Do you want to establish a connection to the parent node from this node? [Y/n]: y
Please specify the master/satellite connection information:
Master/Satellite endpoint host (IP address or FQDN): <Provided icinga master ip>
Master/Satellite endpoint port [5665]:
Add more master/satellite endpoints? [y/N]: n
Parent certificate information:
Subject: CN = <Master icinga2 server name>
Issuer: CN = Icinga CA
Valid From: Oct 29 17:27:06 2019 GMT
Valid Until: Oct 25 17:27:06 2034 GMT
Fingerprint: DD 6C 07 B8 B5 21 B3 89 E6 09 83 93 98 E2 87 CF 02 B1 FE 11
Is this information correct? [y/N]: y
Please specify the request ticket generated on your Icinga 2 master (optional).
(Hint: # icinga2 pki ticket --cn '<Private Ipaddress>'): 323a53a12f62850261e2d36fecd700d2b99b21e5 -> I have ran the pki ticket command with private ip on icinga master
Bind Host []:
Bind Port []:
Accept config from parent node? [y/N]: y
Accept commands from parent node? [y/N]: y
Reconfiguring Icinga...
Local zone name [<Private ip address> ]: Enter
Parent zone name [master]:
Do you want to specify additional global zones? [y/N]: n
Do you want to disable the inclusion of the conf.d directory [Y/n]: n
Done.
This is not working… This is working for the linux which were added in Active directory…
Can someone advise on this? Many thanks in advance
Here, there are couple of things that i would like to address… This ubuntu server is not integrated with AD & I just named it as aws--01..aws in hostfile just for visibility in icinga2 UI… moreover this server aws--01.****.aws is not pingable (just named server internally)…
& in master UI i still seeing the connection issues… which is as shown below…
I just followed the same process for other linux servers which are with Active Directory…never got an issues with those servers… I am only facing for servers that are not in AD in AWS…
Strange… I never changed zones.conf file… I just used the same for all agent installations on remote servers… Here, I have been trying to setup the client setup as shown below… It always works for the servers that are in Active directory… This is not working for servers that are not in AD(AWS ec2 linux instances)…
Bind Host []:
Bind Port []:
Done.
Here, I have tried both the scenarios… Under Please specify the common name (CN) [aws-***-02]:
I have tried both options private ip address & localhost name… Appropriate ticket generated as well…
Both cases not working… I am just worrying any changes needs to be modified for servers that are not AD…
Apologies… if this doesn’t make any sense… Any advise would be appreciated…
