We have noticed that email alerts are not working after enabling notifications and getting below error in log when we manually send notification via web.
Checkable 'hostname' does not have any notifications
Version used: icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.4-1)
Copyright (c) 2012-2019 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 18.04.2 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-1037-aws
Architecture: x86_64
Build information:
Compiler: GNU 7.3.0
Build host: b2ecadfb68ab
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Operating System and version: Ubuntu 18.04.2 LTS
- Enabled features (
icinga2 feature list):Disabled features: compatlog debuglog elasticsearch gelf graphite influxdb livestatus opentsdb perfdata statusdata syslog Enabled features: api checker command ido-mysql mainlog notification - Icinga Web 2 version and modules (System - About):
Icinga Web 2 Version 2.6.3Loaded modulesmonitoring 2.6.3 - Config validation (
icinga2 daemon -C): `[2019-05-09 04:59:06 +0000] information/cli: Icinga application loader (version: r2.10.4-1) [2019-05-09 04:59:06 +0000] information/cli: Loading configuration file(s). [2019-05-09 04:59:06 +0000] warning/Value for constant ‘TicketSalt’ was modified. This behaviour is deprecated. Location: in /etc/icinga2/constants.conf: 29:1-29:53 /etc/icinga2/constants.conf(29): const TicketSalt = “1aa128c057269076519df3bc7695e12b” ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ : [2019-05-09 04:59:06 +0000] information/ConfigItem: Committing config item(s). [2019-05-09 04:59:06 +0000] information/ApiListener: My API identity: icinga.company.build [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘System Load’ (in /etc/icinga2/zones.d/master/services.conf: 8:1-8:27) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘Process’ (in /etc/icinga2/zones.d/master/services.conf: 15:1-15:23) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘Users’ (in /etc/icinga2/zones.d/master/services.conf: 22:1-22:21) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘Disk’ (in /etc/icinga2/zones.d/master/services.conf: 29:1-29:20) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘’ (in /etc/icinga2/zones.d/master/services.conf: 36:1-36:59) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘SWAP’ (in /etc/icinga2/zones.d/master/services.conf: 44:1-44:20) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘FTP Service’ (in /etc/icinga2/zones.d/master/services.conf: 59:1-59:27) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘Icinga2 Service’ (in /etc/icinga2/zones.d/master/services.conf: 67:1-67:31) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘’ (in /etc/icinga2/zones.d/master/services.conf: 74:1-74:71) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] warning/ApplyRule: Apply rule ‘’ (in /etc/icinga2/zones.d/master/services.conf: 82:1-82:66) for type ‘Service’ does not match anywhere! [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 16 Services. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 IcingaApplication. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 4 Hosts. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 FileLogger. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 NotificationComponent. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 ApiListener. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 CheckerComponent. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 3 Zones. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 ExternalCommandListener. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 Endpoint. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 ApiUser. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 1 IdoMysqlConnection. [2019-05-09 04:59:06 +0000] information/ConfigItem: Instantiated 215 CheckCommands. [2019-05-09 04:59:06 +0000] information/ScriptGlobal: Dumping variables to file ‘/var/cache/icinga2/icinga2.vars’ [2019-05-09 04:59:06 +0000] information/cli: Finished validating the configuration file(s).
services.conf :
`apply Service "NS-Client-Version" {
check_command = "nscp"
vars.nscp_variable = "CLIENTVERSION"
vars.nscp_password = "company1234"
vars.nscp_showall = true
assign where host.vars.os_type == "windows"
vars.notification["mail"] = { groups = [ "icingaadmins" ] }
apply Service "RAM-Usage" {
vars.nscp_variable = "MEMUSE"
vars.nscp_warn = 80
vars.nscp_crit = 90
hosts.conf :
`object Host "UTIL-SERVER" {
import "windows-host-template"
address = "192.x.x.X"
check_command = "ping"
vars.nscp_port = 12489 //set the port here, so that services don't need it. the command macro resolver detects that automatically.
vars.os_type = "windows"
enable_notifications = true
object Host "FILE-SERVER" {
address = "10.0.X.X"
users.conf: `/**
* The example user 'icingaadmin' and the example
* group 'icingaadmins'.
object User "icingaadmin" {
import "generic-user"
display_name = "Icinga 2 Admin"
email = "[support@mydomain.com](mailto:support@mydomain.com)"
object UserGroup "icingaadmins" {
display_name = "Icinga 2 Admin Group"
notification.conf : `/**
* The example notification apply rules.
* Only applied if host/service objects have
* the custom attribute `notification` defined
* and containing `mail` as key.
* Check `hosts.conf` for an example.
apply Notification "mail-icingaadmin" to Host {
import "mail-host-notification"
user_groups = host.vars.notification.mail.groups
users = host.vars.notification.mail.users
interval = 2h
//vars.notification_logtosyslog = true
assign where host.vars.notification.mail
apply Notification "mail-icingaadmin" to Service {
import "mail-service-notification"
interval = 2h
