Icinga2 docker container will not deploy due to folder permission
icinga2 - The Icinga 2 network monitoring daemon (version: v2.13.3)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Debian GNU/Linux
  Platform version: 11 (bullseye)
  Kernel: Linux
  Kernel version: 5.4.0-120-generic
  Architecture: x86_64
Build information:
  Compiler: GNU 10.2.1
  Build host: 510a6fe8b7f5
  OpenSSL version: OpenSSL 1.1.1n  15 Mar 2022
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
  • Operating System and version
    Using docker image icinga/icinga2
We are testing the viability of using an Icinga2 container deployed as an Agent at remote locations. The check(s) performed against the remote device downstream from the Agent host will be
  • ICMP using hostalive4
  • SNMP OID queries using ‘check_snmp’
    ‘check_snmp’ requires the presence of snmp in the container, which by default is not. An extended version of the ‘icinga/icinga2’ container was made.
  • Using a certificate from the established master ‘ca.crt’.
    Here is the Dockerfile
FROM icinga/icinga2 AS icinga-snmp
USER root
RUN apt update;\
        apt -y install snmp
RUN apt clean;\
        rm -vrf /var/lib/apt/lists/*
USER icinga
CMD ["icinga2", "daemon"]
After building the Dockerfile for the Agent host, when initiating the Agent the steps fail for lack of credible certificate
docker run --rm --name icinga-agent -h velolabdock
07 -e ICINGA_ZONE=master -e ICINGA_ENDPOINT=icinga-master,velolabdock04.lab.local,5665 -e ICINGA_TICKET="2bc97d05d4cb358
7f10af6aa5046be33399b5644" icinga-snmp
The container stops, as expected do to lack of credible Certificate Authority:
Please copy the public CA certificate from your master/satellite
into '/var/lib/icinga2/certs//ca.crt' before starting Icinga 2.
But when the container is started with an explicit mapping to a valid certificate
7f10af6aa5046be33399b5644" icinga-snmp -v /docker-data/certs/ca.crt:/data/var/lib/icinga2/certs/ca.crt
The initialization process fails due to ‘mkdir’ permissions
[2022-06-25 14:56:36 +0000] critical/DockerEntrypoint: mkdir /data/var/cache: permission denied
The same thing happens when adding CA certificate during the extended container build
USER root
RUN apt update;\
        apt -y install snmp
RUN apt clean;\
USER icinga
ADD ca.crt /data/var/lib/icinga2/certs/ca.crt
Additionally, if ‘USER root’, instead of ‘USER icinga’ is used to initiate the extended container, the same permissions failures cause the container to stop. What step or process is missing to get a working Icinga2 container that has ‘check_snmp’ and can be deployed as a Top-Down Agent
I also get a similar error on the latest tagged icinga2 image (which is 4 months old), but not on master, which was tagged 25 days ago:
$ docker run -it --rm icinga/icinga2:latest
[2025-10-10 23:49:04 +0000] information/DockerEntrypoint: Initializing /data as we're the init process (PID 1)
[2025-10-10 23:49:04 +0000] information/DockerEntrypoint: Checking "/data/etc/icinga2"
[2025-10-10 23:49:04 +0000] information/DockerEntrypoint: Copying "/data-init/etc/icinga2" to "/data/etc/icinga2"
[2025-10-10 23:49:04 +0000] critical/DockerEntrypoint: mkdir /data/etc: permission denied
@tacos: Could you please show which container image version you are using?
$ docker image inspect icinga/icinga2:latest
For the record, the latest latest tag works on my machine™.
$ docker run --pull=always -it --rm icinga/icinga2:latest        130 ↵
latest: Pulling from icinga/icinga2
Digest: sha256:725c982644f406164a8902e988c62ea9a475af496cf07c96cf9ec6dff7b71efb
Status: Image is up to date for icinga/icinga2:latest
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Initializing /data as we're the init process (PID 1)
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/etc/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/etc/icinga2" to "/data/etc/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/var/cache/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/var/cache/icinga2" to "/data/var/cache/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/var/lib/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/var/lib/icinga2" to "/data/var/lib/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/var/log/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/var/log/icinga2" to "/data/var/log/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/var/run/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/var/run/icinga2" to "/data/var/run/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/data/var/spool/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Copying "/data-init/var/spool/icinga2" to "/data/var/spool/icinga2"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Checking "/var/lib/icinga2/certs/ca.crt"
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Looking up "dumb-init" in $PATH
[2025-10-13 07:12:53 +0000] information/DockerEntrypoint: Running "/usr/bin/dumb-init"
[2025-10-13 07:12:53 +0000] information/cli: Icinga application loader (version: v2.15.0)
[2025-10-13 07:12:53 +0000] information/cli: Loading configuration file(s).
[2025-10-13 07:12:53 +0000] information/ConfigItem: Committing config item(s).
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 NotificationComponent.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 CheckerComponent.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 User.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 UserGroup.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 3 TimePeriods.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 3 ServiceGroups.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 11 Services.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 3 Zones.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 12 Notifications.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 2 NotificationCommands.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 IcingaApplication.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 Host.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 2 HostGroups.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 1 Endpoint.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Instantiated 247 CheckCommands.
[2025-10-13 07:12:53 +0000] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2025-10-13 07:12:53 +0000] information/ConfigItem: Triggering Start signal for config items
[2025-10-13 07:12:53 +0000] information/NotificationComponent: 'notification' started.
[2025-10-13 07:12:53 +0000] information/CheckerComponent: 'checker' started.
[2025-10-13 07:12:53 +0000] information/ConfigItem: Activated all objects.
What is your host OS? Are you using Docker, Podman or something else? Anything non-standard in your configuration?
Even if not related to the problem at hand, I would recommend @yhabteab’s recent blog post about the changes to our container build process, such as switching from the master tag to edge.
@alvar, Hey, sorry that I didn’t see your reply earlier. I noticed that I had various permissions issues with my Docker rootless mode installation, so I tried wiping its data and starting from scratch:
rm -rf ~/.local/share/docker/
But I saw a ton of permissions errors that I had to resolve by running the above command as root. Once I did that, I restarted the docker rootless mode daemon, and now the latest tagged Icinga Docker image is working for me. So it sounds like it was an issue with my installation, even though there was a tagged release since I ran into that issue.
