Hi all,
I am using 2 master with 2 icingaweb2 and 2 satellite 2 db
service checks are not regularly running on master
also Secondary Master does not publish any data from primary master
means if we delete something in Primary Master it is not reflecting to secondary
master
cheers,
Kawhi
stevie-sy
(Stevie Sy)
2
to help you we need more information:
- your installed icinga2 version
- the output of icinga2 feature list
- your configuration from /etc/icinga2/zones.conf
- are thre errors in your icinga2.log and the debug.log (if enabled)
take also a look into: https://icinga.com/docs/icinga2/latest/doc/15-troubleshooting/
stevie-sy
(Stevie Sy)
4
sorry I don’t know what exactly your idea is. Maybe you can make a sketch what you imagine.
Do you mean? two diffrent database systems? icinga should use two diffrent databases?
Maybe this chapter from the docs helps: https://icinga.com/docs/icinga2/latest/doc/06-distributed-monitoring/#high-availability-with-db-ido
Hi Kawhi,
There’s a few things we’d want to see here, can we see the zones.conf from both masters, as well, on the secondary master make sure that:
include_recursive "conf.d" is commented out (//) in /etc/icinga2/icinga2.conf
- /etc/icinga2/features-available/api.conf should look like this:
object ApiListener "api" {
accept_config = true
accept_commands = true
