I have two icinga nodes in a master-master setup.
When the first master is “in charge”, everything works fine.
When the second master is leading, there are some errors:
Some config files can’t be accessed (e.g. the one with ipmi credentials, let it be /etc/icinga2/zones.d/master/hosts/ipmi/ipmi.cfg
The second master stores its temporary config in /var/lib/icinga2/api/zones-stage/master/_etc/hosts/ipmi/ipmi.cfg
but it tries to use the one from /etc/icinga2/zones.d/...
as configured in the host file:
vars.ipmi_config_file = [ SysconfDir + "/icinga2/zones.d/master/hosts/ipmi/ipmi.cfg" ]
is there a possibility to get this running without abstaining from the use of the separate ipmi.cfg file?
- When the issuing of checks is distributed about both masters and master2 is the check source, there sometimes is the error message “master2 is not connected to host-xy”.
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.3-1)
System information:
Platform: Debian GNU/Linux
Platform version: 12 (bookworm)
Kernel: Linux
Kernel version: 6.1.0-28-amd64
Architecture: x86_64
Enabled features: api checker debuglog graphite icingadb mainlog
Icinga Web 2 Version 2.11.4
PHP Version 8.2.26
Get Icinga Support
Icinga Community
Report a bug
Icinga Documentation
Loaded Libraries
icinga/icinga-php-library 0.10.1
icinga/icinga-php-thirdparty 0.11.0
Loaded Modules
icingadb 1.0.2 Configure
graphite 1.2.2 Configure
Copyright © 2013-2024 Icinga GmbH
[2024-12-10 12:32:47 +0100] information/cli: Icinga application loader (version: r2.14.3-1)
[2024-12-10 12:32:47 +0100] information/cli: Loading configuration file(s).
[2024-12-10 12:32:47 +0100] information/ConfigItem: Committing config item(s).
[2024-12-10 12:32:47 +0100] information/ApiListener: My API identity: ....de
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'startpatch-downtime-sunday2' (in /etc/icinga2/zones.d/master/downtimes.conf: 28:1-28:61) for type 'ScheduledDowntime' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'startpatch-downtime-sunday4' (in /etc/icinga2/zones.d/master/downtimes.conf: 39:1-39:61) for type 'ScheduledDowntime' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'startpatch-downtime-sunday2-4' (in /etc/icinga2/zones.d/master/downtimes.conf: 50:1-50:63) for type 'ScheduledDowntime' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'procs' (in /etc/icinga2/zones.d/master/services.conf: 42:1-42:21) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'apt' (in /etc/icinga2/zones.d/master/services.conf: 166:1-166:19) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'ping6' (in /etc/icinga2/zones.d/master/services.conf: 194:1-194:21) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'iscsi' (in /etc/icinga2/zones.d/master/services.conf: 206:1-206:21) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'check_gpu' (in /etc/icinga2/zones.d/master/services/nvidia-smi.conf: 1:0-1:24) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'cluster' (in /etc/icinga2/zones.d/master/services/pve.conf: 8:1-8:23) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'services' (in /etc/icinga2/zones.d/master/services/pve.conf: 16:1-16:24) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'updates' (in /etc/icinga2/zones.d/master/services/pve.conf: 30:1-30:23) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'io_wait' (in /etc/icinga2/zones.d/master/services/pve.conf: 50:1-50:23) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'pve-vm ' (in /etc/icinga2/zones.d/master/services/pve.conf: 92:1-92:72) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] warning/ApplyRule: Apply rule 'check_nfs-common' (in /etc/icinga2/zones.d/master/services/systemd.conf: 9:1-9:32) for type 'Service' does not match anywhere!
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 2 NotificationCommands.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 555 Notifications.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 8 HostGroups.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 103 Hosts.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 5 Downtimes.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 796 Dependencies.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 IcingaDB.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 2 FileLoggers.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 86 Zones.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 User.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 86 Endpoints.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 4 ApiUsers.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 259 CheckCommands.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 GraphiteWriter.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 1 UserGroup.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 9 ServiceGroups.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 4 TimePeriods.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 7 ScheduledDowntimes.
[2024-12-10 12:32:48 +0100] information/ConfigItem: Instantiated 796 Services.
[2024-12-10 12:32:48 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2024-12-10 12:32:48 +0100] information/cli: Finished validating the configuration file(s).
