Hello
If you want to get notification on specific drives, you need ti change the check to test the specific drive.
By default the plugin, if not specific disk is defined, will check all available partitions ( disks) and will report back on all of them regardless of status.
If one of them answer the criteria of the thresholds, then it will send the notification, but with the information on all the disks in the data accompanying the notification.
I can define the service checks for specific drives. But the problem there are bunch of windows servers with drive K, M & N where other servers have doesn’t…
I would like to understand how can we handle this? Any help that i can get here? …
You can create a template with the check for the K,M & N and add the hosts that have those drives to a host group and then use an assign rule to apply those checks to the hostgroup.
Thanks again… looks like its long process… We have around 200-300 windows… every server has different drives lots of servers doesn’t have D drive or any other drive… Every server has different number of drives…
looks like i need to do analysis what kind of drives that are available for all servers… Based on those i need to create hostgroups & need to make apply rules? or any other simpler process like service checks query the list of drives on server & if any drive has issues it should notify something like that?
Sorry if this is not possible at all… Can you please advise on this? thanks in advance
so basically if I understand you correctly monitoring all drives vom A-Z is your intention with lets say warning on 20% free and critical on 10% free - correct?
You do how ever want to only add the drives inside your notification that are “bad” instead of adding all 10 drives (C-L) for example - correct?
