Icinga2 director loop
Loop detected: nvidia → nvidia (TemplateTree.php:225)
using director
cannot deploy someone can help ??
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 22.04.4 LTS (Jammy Jellyfish)
Kernel: Linux
Kernel version: 5.15.0-113-generic
Architecture: x86_64
Build information:
Compiler: GNU 11.4.0
OpenSSL version: OpenSSL 3.0.2 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Screenshot 2024-07-01 171034
your service template tries to import itself.
you can fix that by reverting steps in the activity log or fixing the database manually
Hi
I tried to revert but still same error
I do not have an id error so i do not know what to remove from the database???
it is very similar to the host inheritance problem.
what’s the output from this query?:
SELECT * FROM icinga_service_inheritance where service_id = parent_service_id
MariaDB [director]> SELECT * FROM icinga_service_inheritance where service_id = parent_service_id;
| service_id | parent_service_id | weight |
| 1324 | 1324 | 1 |
1 row in set (0.001 sec)
thanks you are an angel
this do the trick :grin::pray:
DELETE FROM icinga_service_inheritance where service_id =1324;
