Icinga2 DateTime() function not working as expected
Dear experts,
Im using Icinga2.11 on RHEL os. Im using DateTime() function using macros in a service definition.
This function is not working as expected. I mean when i restarted/reload the icinga2 services then it is showing the correct date otherwise always it is showing the old date of when i had restarted/reloaded the services.
vars.daybefore = (DateTime() - (24 * 60 * 60)).format("%Y%m%d")
Can you please help in fixing this.
with Regards,
Krishna Rajapantula
this will not really work. i think it should be (untestet)
vars.daybefore = {{ return "" + (DateTime() - (24 * 60 * 60)).format("%Y%m%d").to_string() + "" }}
Regards,
Carsten
Thanks Carsten…Let me test this and update you.
With Regards,
Krishna
Thanks Carsten, it is working as expected.
