In this link the troubleshooting documentation there is a step to run icinga2 daemon -C --dump-objects (and I found I can add --validate to it: icinga2 daemon -C --validate --dump-objects) it states to run icinga2 daemon -C --dump-objects to update the icinga2.debug cache file. I found that initial command from a warning I got when investigating some objects in Icinga: “warning/cli: This data is 271 days, 7 hours, 35 minutes and 47 seconds older than the last Icinga config (re)load. It may be outdated. Consider running ‘icinga2 daemon -C --dump-objects’ first.”
Does running icinga2 daemon -C --dump-objects or icinga2 daemon -C --validate --dump-objects cause any potential issues or impacts to a current running Icinga2 environment? Or can this safely be ran without expecting an impact, such as running icinga2 daemon -C?
Thank you.
- Icinga Web 2 version - 2.11.4
- Used modules and their versions (System - About) - Grafana 2.0.3, Icingadb 1.0.2, Monitoring 2.11.4
- Web browser used - Chrome, Edge, etc
- Icinga 2 version used (
icinga2 --version) - 2.11.4 - PHP version used (
php --version) - 8.1.2-1ubuntu2.13 - Server operating system and version - Ubuntu Linux
- Config validation (
icinga2 daemon -C) - Icinga application loader (version: r2.14.2-1)
