Hi
I am trying one agent with 2 satellite setup
followed above link but seems i miss something
what is the step by step procedure to do the certificate signing to talk with both the satellites?
note from agent to satellite the port 5665 is open
below steps i have done
mkdir -p /var/lib/icinga2/certs
chown -R icinga:icinga /var/lib/icinga2/certs
icinga2 pki save-cert
icinga2 node setup
warning/cli:
No connection to the parent node was specified.
information/cli: Requesting certificate without a ticket.
warning/cli: Node to master/satellite connection setup skipped. Please configure your parent node to
connect to this node by setting the 'host' attribute for the node Endpoint object.
information/cli: Using the following CN (defaults to FQDN): 'agent1'.
information/base: Writing private key to '/var/lib/icinga2/certs//agent1.key'.
information/base: Writing X509 certificate to '/var/lib/icinga2/certs//agent1.crt'.
warning/cli:
Please copy the public CA certificate from your master/satellite
into '/var/lib/icinga2/certs//ca.crt' before starting Icinga 2.
