I am trying to setup Icinga2 + Director as a school project and I came across some problems while trying to do a test host check for google. So the problem is most likely because I didn’t configure something right .
I tried the command icinga2 feature enable command to quick fix my problem but now the error doesn’t pop up and it is still pending.
zones.conf:
object Endpoint “monitoring-master” {
host = “127.0.0.1”
port = 5665
object Zone “master” {
endpoints = [ “monitoring-master” ]
object Endpoint NodeName {
host = NodeName
object Zone ZoneName {
endpoints = [ NodeName ]
global = true
global = true
I am using the newest versions 22.04.3 on ubuntu
