Icinga2 change hostname at host level and Icinga director level (all entries)
Already tried one topic but it didn’t work:
change hostname at OS level
rm /var/lib/icinga2/ca/*
rm /var/lib/icinga2/certs/*
rm /var/cache/icinga2/*
icinga2 feature disable api
vi /etc/icinga2/constants.conf
icinga2 api setup
icinga2 daemon -C
I generated few scripts also with AI, but they don’t seem to effectively change all zones(hostname) entries.
Information about Icinga:
  • version: r2.14.2-1
  • Debian GNU/Linux 11 (bullseye)
  • Enabled features: api checker icingadb ido-pgsql mainlog notification
  • Icinga Web 2 Version 2.12.1
  • Modules:
    |businessprocess||2.4.0|
    |director||1.10.2|
    |doc||2.12.1|
    |icingadb||1.1.2|
    |graphite||1.2.2|
    |incubator||0.20.0|
    |migrate||2.12.1
    |nagvis||1.1.1|
    |pdfexport||0.10.2|
    |reactbundle||0.7.0|
    |reporting||0.10.0|
    |translation||2.12.1|
    |vspheredb||1.7.1|name=vspheredb)||x509||1.1.2|
The problem is because i migrated all the entries from old Icinga (with old ido monitoring) to new backend Icinga. I still need most of the command templates, services, hosts, etc.. And I wasn’t able to find or effectively solve all the changes on the director/api packages level the most. If somebody was able to do it, I would be grateful for procedure.
