Hi, i have a dedicated webserver for icingaweb2 and behind two HAProxys with keepalived two icinga-master.
Should the Icinga API also be published on the HAProxy for High Availability? I need one address for the Command Transports in Icinga Web 2.
Hi Robert,
you can if you want. But there is no need for it, just configure both APIs as command transport in Icingaweb2.
Regards,
Carsten
Really? Great, i will try.
Thank you
