Ah! Currently I’ve NRPE based checks on the clients. If I install the Icinga2 agent on the clients, how to convert those tests into the agent and how the mapping work as mentioned below?
The icinga2-client1.localdomain node maps the command parameters to the local check command, executes the check locally, and sends back the check result message.
