Icinga2 agent on Ubutnu Semaphore Usage
I have Icinga2 2.13.3-1 running on Ubuntu 18. On two servers it is fine but I’ve just set it up on a third and when running it keeps using Semaphores and not releasing them. I have to stop Icinga2 and manually remove them. After 1 hour of running it’s using 4000. By comparison the other ubuntu hosts, running the same version, have been online for months and they are using 9…
Any ideas??
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.3-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Ubuntu
  Platform version: 18.04.6 LTS (Bionic Beaver)
  Kernel: Linux
  Kernel version: 4.15.0-206-generic
  Architecture: x86_64
Build information:
  Compiler: GNU 8.4.0
  Build host: runner-hh8q3bz2-project-298-concurrent-0
  OpenSSL version: OpenSSL 1.1.1  11 Sep 2018
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
are you trying to create a “three master”-setup?
that’s not supported
Also not supported for any other zone besides the master zone as well.
Only one master - the systems I was talking about are all running agents (the master is a seperate server).
Two of the agents work fine but the third keeps consuming and not releasing semaphores. OS and Icinga code and even configuration are the same on all three.
Every Agent is in it’s own zone?
It is - but only because that was the way I got it working a few years ago - I wasn’t sure if it was the right way or not…
It is the right way as you can have only 2 nodes per zone and all endpoints need to belong to a zone:
Master Zone: master1 [& master2]
[Satellite X Zone: satellite_X_1 [& satellite_X_2]]
Agent Y Zone: agent_Y
means optional
So in the end I also only have one zone per agent and I call both the endpoint and the zone by the FQDN of the host the agent is running on.
off topic but how did you get Icinga 2.13 running on bionic?
Hello @rudders!
Which “Semaphores” and how to list the unreleased ones?
