Hello I am new to the Icinga2 Community,
sadly i don’t know if it is a configuration error on my part, or if it’s just a bug with Centos 8 and an icinga2 agent.
So here is my problem:
the icinga master is completely configured and is already monitoring some of the virtuell devices in our network. After I tried to connect an icinga2 agent on centos 8 to the master, icinga gave me this output:
“Check Command check_mem does not exist”
After a long search trough the logs i found this:
“executing command ‘opendir’ /var/lib/icinga2/api/zones/zonename/_etc error code 13 ‘Permission denied’”
So I checked the permissions on the directory and icinga already got full permission to read an write into it.
with kind regards
Kevin Weller
