Hello guys.
I have a master with one endpoint (just testing) and I have graphite enabled en master. Graphs show when service is from master, but when is of endpoints doesn’t show. Some can help me please? I stuck in this many days.
Thank you
Master
Endpoint(Agent)
dgoetz
(Dirk Götz)
February 25, 2021, 9:01am
2
To find the cause of the problem I would check:
Is enable_perfdata set to true (default) or false for this service?
Are there log messages about invalid perfdata in the icinga.log?
Are there log messages about connection problems to graphite?
Is the creates.log enabled for graphite? If yes, are there entries for the metrics?
Are there many metrics incoming to graphite? If yes, the python version limits by default to 500 creates per minute.
Are the files on the disk created like expected? Should be /var/lib/carbon/whisper/icinga2/limprdnfs/services/load/load/perfdata/value.wsp.
