Hi
Does anyone know the default login and password for the Icinga1 Classic Web UI? Is there any file I
should look at on the host to find out the default login info?
Hi
Depends on its configuration, likely you can find the details in the archived docs. Classic UI and all other 1.x components are end of life since 2018, so you won’t receive any (security) updates anymore.
Thanks Michael. I could not find the 1.x documentation. Can you share the link for me?
Thanks much
Never mind. I found it - https://icinga.com/docs/icinga1/latest/en/
