I am trying to get icinga working on my server but it keeps failing tryed many howto’s
But all result with corupt css files if i have a look at icinga.min.css it contains this including a stack dump:
Operation on an invalid type
#0 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Expression.php(51): Less_Tree_Operation->compile()
#1 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Call.php(44): Less_Tree_Expression->compile()
#2 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Expression.php(51): Less_Tree_Call->compile()
#3 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Value.php(26): Less_Tree_Expression->compile()
#4 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Rule.php(73): Less_Tree_Value->compile()
#5 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(91): Less_Tree_Rule->compile()
#6 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(91): Less_Tree_Ruleset->compile()
#7 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(185): Less_Tree_Ruleset->compile()
#8 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(130): Less_Parser->getCss()
#9 /usr/share/php/Icinga/Web/LessCompiler.php(230): lessc->compile()
#10 /usr/share/php/Icinga/Web/StyleSheet.php(218): Icinga\Web\LessCompiler->render()
#11 /usr/share/php/Icinga/Web/StyleSheet.php(258): Icinga\Web\StyleSheet->render()
#12 /usr/share/php/Icinga/Application/webrouter.php(64): Icinga\Web\StyleSheet::send()
#13 /usr/share/icingaweb2/public/index.php(4): require_once('/usr/share/php/...')
#14 {main}
.. 07143em;
vertical-align: 0.05357em; }
.fa-lg {
font-size: 1.25em;
line-height: 0.05em;
vertical-align: -0.075em; }
.fa-xl {
font-size: 1.5em;
line-height: 0.04167em;
vertical-align: -0.125em; }
.fa-2xl {
font-size: 2em;
line-height: 0.03125em;
vertical-align: -0.1875em; }
.fa-fw {
text-align: center;
width: 1.25em; }
.fa-ul {
list-style-type: none;
margin-left: var(--fa-li-margin, 2.5em);
padding-left: 0; }
.fa-ul > li {
position: relative; }
.fa-li {
!! left: calc(var(--fa-li-width, 2em) * -1);
position: absolute;
text-align: center;
width: var(--fa-li-width, 2em);
line-height: inherit; }
.fa-border {
border-color: var(--fa-border-color, #eee);
border-radius: var(--fa-border-radius, 0.1em);
border-style: var(--fa-border-style, solid);
border-width: var(--fa-border-width, 0.08em);
padding: var(--fa-border-padding, 0.2em 0.25em 0.15em); }
.fa-pull-left {
float: left;
margin-right: var(--fa-pull-margin, 0.3em); }
.fa-pull-
- Icinga Web 2 version 2.10.1-1.focal
- Used modules and their versions (System - About)
- Web browser used chrome
- Icinga 2 version used (
icinga2 --version
) - PHP version used (
php --version
) 8.0.20 - Server operating system and version ubuntu 20.04
